pitchinjigs
- May 4, 2008
- 2
hello, i have a 1975 johnson 70 seahorse. it has ran fine all year, this past weekend i was idleing around and it died in gear. i have tested for spark and the motor cranks but has none. when cranking the motor i have no voltage coming in or out of the powerpack, which makes me believe i have no voltage coming from the ignition switch to the powerpack. am i correct in understanding i should have voltage on the black and yellow wire from the ignition switch. ive been reading some other posts and i believe i have a problem with the ignition switch or powerpack. i have been trying to troubleshoot using this black and yellow wire at the powerpack, when disconnected from the powerpack there is still no spark. any advise or suggestions are greatly appreciated. thanks in advance, russell
