Re: 1993 johnson 48 hp spl
Just a matter of removing the control cable & the pins, top & bottom.
Had to do the same on mine last year. Remove the top pin using a slide hammer, to back it out - the lower tilt pin by removing a nut from 1 side & tapping it out.
DAVY
