carb rebuild kit has no info on setting idle jet .turned in 13 times?
P pete6464 Cadet Joined Apr 26, 2008 Messages 21 Apr 26, 2008 #1 carb rebuild kit has no info on setting idle jet .turned in 13 times?
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Apr 26, 2008 #2 Re: 1993 johnson 48 hp spl Check out the FAQ here on iboats. There will be a thread by Joe Reeves which will pertain to you.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Apr 26, 2008 #3 Re: 1993 johnson 48 hp spl you rcarb has fixed jets, there is an adjustment that is set at the factory, if messed with you need the OEM manual to reset
