Is there anyway to test the distributor and rotor to find out if they are too worn? I have good spark up to the wire going into the distributor, but nothing going out to the plugs. I have cleaned all the brass areas and checked for cracks etc. but is there any other test that I can do to see if it is making contact. May be orginal, and the brass on the rotor seems quite worn. Any ideas?
