davidf5252
- Apr 19, 2008
- 168
I just bought a boat and it has a 1956 Johnson Javelin 30hp motor on it..i cleaned the carb and patched the fuel tank so it will hold pressure...
now that i have it running it sputters a bit but not to bad...However i put it in a big tub of water and let it run for a few minutes and it seems exhaust is coming out of both holes on the back of the motor...(right above the prop and the other half way up on the back towards the motor) NO WATER at all is coming out of any where that i can see and the water splashing up on the boot is sizzling off its so hot..
is there supposed to be water coming out some where? This is my first boat and i have no idea what i am doing..
Thank you all in advance for the help and if it would be easier you can give me a call 404 456 6826.
Again, thank you.
edit: pics added page 4
Again, thank you.
