MN_fisherman
- Mar 4, 2008
- 21
Does anyone have any tricks for improving the function of the pinion gear on these motors. In order for the nylon pinion to rise up and engage the flywheel you have to really jerk on the starter rope which sort of bothers me since I prefer to pull the rope slowly until I feel the recoil engage then let 'er buck. Under the pinion there is a spring which I assume has something to do with the function of the pinion. The teeth are on the pinion are worn but there are no other noticeable cracks or defects. What I'm wondering is if anyone here knows how to make this set up work better. Thanks in advance.
