ehenry
- Jan 6, 2002
- 2,393
I know I've seen this problem posted before but danged if i can find it.......this engine cranks fine. When you open the throttle it will reach 44-4500 rpms. After about 10 to 20 seconds the rpms drop back to 2800 to 3000 with throttle wide open. If you push the choke the rpms will go back up to 44-4500 for about 10 to 15 seconds and fall back again.
