MN_fisherman
- Mar 4, 2008
- 21
I have a model 9622A evinrude 9.5 and I'm wondering about the availability of a repair kit for its fuel pump. The pump it has is a little different than some of the newer ones I've seen. It has six screws (three on top and three on bottom) plus one in center. The inlet and outlet barbs are both on the left side and the two top corner crews hold it to the powerhead. I can't find a replacement kit listed specifically for the 9.5 and I want to make sure I get the right one. Can anyone here tell me the part number of the repair kit that I need. I'm also looking for the carb float assembly. If anyone knows of a source for just the plastic float I'd be interested. I see that the factory carb kits come with a new float but all I need is a new float to replace the cork one I currently have. I have heard that there is some stuff that can be used to coat the cork float but it would have to be resistant to the alcohol added to the fuel. I think plain old varnish would quickly break down. Anyone know of a proven substance that will wirk for this purpose?
