I have a issue with my 25hp sportster. I ran it the other day and it overheated. I have full spray of water coming out. So I thought the thermostat was bad?? It looks brand new. Then I thought may the water jacket was clogged up. I pulled it all apart and cleaned every square inch,put it all back together started up on the fist pull and still seems to be runnig hot. Any advice on my next move?? I also pulled the thermostat cover of the top of the motor after I ran it and it was dry. Should there be water in it after it runs? How hot does the block get??
Thanks for any advice, Steve
