Kajun37
- Feb 17, 2006
- 348
this is my first complete rebuild...and this is the first time i started it up..its knocking real bad...i'm guessing that the timing is way off? what would cause this knock?
also it seems to be running hot, i couldnt hold my hand on the powerhead for long, but it seems to be pumping water good? it had water coming out the exhaust hole and 2 holes in the bottom frony on the leg..... it has the old impeller on it though...i have a new impeller to put on it and will do so before i start it up again.
when i bought it($100), it was completely frozen..had to take it apart to get it unstuck.....i had the cyl's honed and put new rings on it, rebuilt carbs, put new condenser and points and 2 new coils on it, new fuel lines, new spark plugs...so far i got approx. $400 into it.
here is the video of the first time i start it up ...any ideas on the knock?
http://www.youtube.com/watch?v=FwFQ...s.iboats.com/newthread.php?do=postthread&f=24
before and after pics....
