Re: 1935 johnson J75 need a set of points
Unless you get REALLY lucky, you're not likely to find new points for it. However, it is fairly rare that the original points can't be dressed and put back into service. I can't recall if those points are able to be disassembled, but if so, clean up the two contacts with a fine file, crowning the contact area just a hair. Reassemble and gap them at .030". Condensers might have a modern equivalent if you can find the ?f (microfarad) rating for it. Those coils are generally fairly reliable, even after close to 75 years!
- Scott
