Hi, I just picked up a 28 SPL for my small boat and I have a couple questions, you guys have always been helpful in the past...
Took the motor out today and after putting the boat back on the trailer I noticed a combination of water and oil or grease squeezing out of this hole in the foot. There are 3 such holes, is this missing something? I've never noticed anything like this in other outboards. The plate at the top is also missing a screw and the same type of oil/water mix is seeping out of there too.
I drew arrows to the holes. The bottom one you can really see the oil seepage. The two upper ones arent really seeping anything, there just there...what are these for?
Also this joint is barely holding together cause only 1 screw is holding that plate in. THe other screw is broken off in there. Should I drill, or could I cause more problems if I drill too far in?
Should I run 100:1 or 50:1 gas oil ratio?
How difficult is it to convert the long shaft design to a short? Should I just get a very high jackplate and mount it up on the transom instead?
Thanks in advance yall.
