catalyst-519
- Mar 12, 2008
- 64
Rebuilding carb on a '64 Johnson 5.5hp. Have the Original service manual and it calls for a special tool to remove the fixed jet behind the drain screw in the float bowl orifice.
Have called a couple marinas and the mechanics said just use a tight fitting flat head screw driver. I don't want to do this and risk mangling the jet.
Can you still find these tools or do you have to fab one for yourself.
Any suggestions would be greatly appreciated.
Cheers--519
Cheers--519
