1950's evinrude gas/oil ratio
Dutch515
I all in new to the site and had a question I hope you can answer for me.
I just picked up a 1953-54 Evinrude 25 hp big twin and a 1953-54 Evinrude 15 hp fastwin. What gas oil ratio did these early models use. I heard in the sixties 50:1 was common. I would just like to use the correct ratio. Dutch
Dutch515
Re: 1950's evinrude gas/oil ratio
id also like to know the high and low screw settings for both. Thanks, Dutch
wbeaton
Nice motors. I have both. Post your model and s/n numbers and we can tell you what years you have.
24:1 in both. Synthetic oil will smokeless and won't leave a big oil sheen on the water. 1.5 turns out on the low and 1 turn out on the high is a good starting point for the jets. You have to make the final adjustments on the boat. Someone will come by with Joe Reeves carb set up procedure.
Dutch515
Thanks guys for the info, I usually do just vintage sleds but a friend has 9 of these old motors and wanted me to fix em all up. The 15 hp evinrude serial # is 15012 - 02891 and the 25 hp evinrude is 25012 - 32748. I also have a Montgomery ward sea king if anyone can help I think its a 51 but heres the #'s
Model # 15GG - 9015
Serial # - 389989
Thanks again guys your awesome. I think Ive found a great site to start me new obsession. Dutch
HighTrim
Evinrude #15012 is a 15hp 1953-54
Evinrude #25012 is a 25hp 1953-54
wbeaton
15012 - 02891 = 1953 Evinrude Super Fastwin 15 hp
25012 - 32748 = 1953 Evinrude Big Twin 25 hp
15GG-9015A = 1951 Montgomery Ward Sea King 5 hp
Send me a PM with your email address and I'll send you the parts manuals for your Evinrudes.
tmcalavy
You can get an owners manual/guide for that Sea King from acmeoutboards.com
Nice little motors, very reliable.
