Re: How to adjust '92 Johnson 9.9 gear shift?
Ezeke,
The shift rod on this 9.9 comes up through the top of the cowling and looks ok,. I took the shift roller off and it seemed to work ok. I noticed the threads that hold the bolt and roller on were stripped and wouldn't hold it solid. Maybe it was preventing smooth shifting. I'll let you know what happens. I may just epoxy it in. Thanks.
