Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1978 evinrude 115 impeller replacement?
  • 1978 evinrude 115 impeller replacement?
    How often should the waterpump or impeller be changed? The last time mine was changed was right before I bought the boat. I have owned it for about six years now. Any suggestions are welcome and thank you in advance.
    Re: 1978 evinrude 115 impeller replacement?
    Welcome to iboats Gator.
    I would say you are due. Most agree that every 2 to 3 years is standard, depending of course on hours used and the conditions that the outboard is used in. It is a fairly inexpensive part as you know, and can be changed in under an hour. Its failure is catastrophic. Personally, I change mine every second season, along with the t stats. I like having the peace of mind, plus I know the price of replacement power heads.
    Chris
    Top Secret Files:
    http://forums.iboats.com/showthread.php?t=299680
    PROUD NOW OWNER OF SITE DEDICATED TO ANTIQUE AND VINTAGE OUTBOARD
    MYOLDBOATMOTOR.COM
    • #3
      I would change the impeller as a precaution. Be aware when ordering that you need the correct impeller. The ones for the newer models do not have the same key and slot that yours does. They were changed with the 1979 - 1980 models.
      • #4
        sounds like this would be a good time to replace mine. I only get to take out my boat 3-4 times a year. Better safe than sorry!!
        • #5
          My seial # is 115899c from what i could tell it is a '78. Sound right?
          • #6
            78 is correct
            Chris
            Top Secret Files:
            MYOLDBOATMOTOR.COM
            • #7
              Thank you.
              • #8
                I also have the same outboard engine. 1978 evinrude 115 model #115899. Problem is I can't find a water impeller replacement kit for this engine anywhere. Any suggestions?
                • #9
                  Here is the Sierra kit, available here at iboats
                  http://www.iboats.com/mall/partfinde...****=275839265
                  You can also go to "www.shop.evinrude.com" for the OEM kit
                  Chris
                  Top Secret Files:
                  MYOLDBOATMOTOR.COM
                  • #10
                    If you just want the impeller, the Mallory impeller is the best iboats price: http://www.iboats.com/mall/partfinde...****=209184253
                    Ishopmarine still lists the Sierra impeller 18-3043 at $20.US and change.
                    Back to Top
