patrick4266
- Nov 29, 2007
- 591
I just replaced the impeller on this. Those electric wires were really tricky to get back in and so was lining up the plastic tubes on the water pump. I have it tilted up and had to put a rubber bungie cord to hold it up while i slid the driver shaft in. I had to turn the flywheel to get it to slide up there and managed to get the bolts started. My question is this. As I have it in that far, does that mean the drive shaft splines are in and lined up right? I think I have it right but I want to be sure before I tighted it down tomorrow.
