Tao of Funk
- Nov 8, 2007
- 58
I found a crack in my distributor, it on the bottom near one of the terminals for the spark plug wire. I think the distributor is also slightly squished as well because when the motor heats up the "points plate" that rotates for spark advance hangs up. I have added shim washers under the distributor and it fixed the spark advance problem. Aside from any advice about the current condition of the distributor:
Where can I get a replacement distributor? I can not find one online anyway.
I have read posts about people replacing the distributor with one off of a Ford. If you have done this or know about switching the entire distributor system to something else I'm all ears.
Thanks!
GB
Thanks!
GB
