I have an Evinrude 1992 40hp outboard, model 7E40ELEN.
The starter drive "whirs", but doesn't raise up to engage the flywheel. I've cleaned the battery connections and checked the starter fuse.
Could this be the solenoid? Is there an easy way to check, or just replace?
What about the starter motor? How do I check? Am I better off just to replace the solenoid, and go from there?
Thanks!
Thanks!
