Hi,
Due to broken wires where they flex, I've replaced the "stator" (like a PU coil) and and the coil under the flywheel. The guy at the place I bought the parts from (local) had the alignment ring so they're properly aligned but I forgot to ask for the torque spec on the flywheel nut.
Anyone here know that and have a good method to keep the engine from turning while torqueing? I used an impact gun and puller to remove it but I won't impact it back on, too risky IMO. I might be able to find a tool at work that'd hold the flywheel but I'd like to know what you guys use otherwise.
There use to be an online repair manual here at iboats for the Evinrude 9.9-15 HP and I had it bookmarked but it's no longer there. Anyone know what happened to it, still available somewhere? Google doesn't find it either.
