Re: 1988 15hp Johnson: Bringing it back from the dead
Question from down-under...
I have a Johnson 15hp, 1987 model, which suffered a thermostat failure and consequent overheating and seizure.
Without any real prior experience but with assistance from forums like this (which are a great help), I stripped the motor down and replaced some gaskets and the thermostat. In particular, I have replaced the grommets at the top of the water inlet and outlet pipes, which had ?melted? practically shut.
I have also had a marine mechanic look at the compression, which I am told is ok. (The mechanic started the motor (before I had replaced the grommets) and said that it seemed ok but for the water flow- hence the grommets being replaced).
Having stripped the power head and replaced the gaskets, this weekend I put the motor back together and, with trepidation, pulled the starter cord. I am met with a motor that will occasionally ?kick?, but won?t fire up.
The spark plugs have been replaced, but not the coils and leads- I am working on the assumption that if the mechanic was able to get it started, these should be ok.
I have not replaced the fuel- which is probably 4 months old, but has been stored in a garage and in mild conditions.
Any ideas or suggestions for getting the motor to start greatly appreciated.
