Re: replace manual fuel pump with electric 87 2.7l seadrive
fire hazard, if motor stalls the pump will keep pumping, until the key is turned off. on an inboard there is a oil pump stitch, which shuts the pump off if no oil pressure, since an outboard is 2 cycle the is no oil pressure.
