kulhndluke8
- Sep 18, 2007
- 8
I am posting this again for more of your answers. I received such good input last time. I need some more help.
I think that the engine is starving for fuel??????????
I have changed all lines.
OMC Primer bulb
Checked pickups in tanks ( all Clean )
new fuel filter
I went to the lake Saturday and it started fine. Upon acceleration engine will sputter like it wants to cut out. Can get on plane and run to around 4200 rpm. If I try and go any faster that that the engine will start cutting out and then just shut off. When it shuts down I can pump the bulb a couple of times and will start right back up. The bulb is pretty hard when I do this. Some times I can run for around 5 miles and it will run fine but then it seems when I try run again it will do the same thing. Please Help!!!!!!!!!!!!
OMC Primer bulb
new fuel filter
