I desparately need help to set the timing belt for my 1965 evinrude outboard engine. I have the service manual and follow the intruction by setting the flywheel timing mark aligned with the mark on the engine block. Then I set the magneto flywheel breaker setpoint mark aligned with the mark on the plate. Intalling the belt based on these two setting. But the engine still not start and had backfire. I got spark on four cylinder with 3/8 gap. New point, carburetor and fuel pump are just rebuilt. The points are set at 0.020 gap at it highest point on the cam. Please guide me how to set the timing for this engine please.Thanks.
