arttheaggie
- Sep 22, 2007
- 2
I am trying to get this motor tuned up to put on my 17' Sailboat.
I completely disassembled it, cleaned the carb, installed new spark plugs, regreased the lower unit, cleared all lines (fuel and water). I only has one needle valve on the carb (I can get it to start and run at higher speeds but can not get it to idle, it does this best at 3-4 turns open from all the way closed). There is also a needle valve behind the fuel tank that looks like it controls the lubrication of the crankshaft. It has to be between 2-3 turns from closed. I have tried various fuel mixtures from 24-1 up to 50-1 and cannot seem to get it to a low speed idle. I have had it running for over 15-20 minutes at a time with the head tempurature only reaching upto 180 degrees at the hottest measured with and infrared temp sensor. Any help with this would be greatly appreciated.
Art Self
Art Self
