Re: How to check oil level on OMC 1.6L?
Howdy, Dan.
Welcome to iboats.
First: Are you sure this is an outboard engine? 1994 outboard engines are 2 stroke engines that are lubricated by the oil that is mixed with the gasoline either when filling the fuel tank or in the fuel pump. There is no oil sump or dipstick, but you need to be sure that there is oil in the oil tank, if you have one. It should have a level indicator on the cap.
There is oil in the foot. It is 90W oil similar to differential oil used in cars. On the side of the foot there are two plugs with screw driver slots. The upper one is the vent and the lower one, called the drain, is used both to drain and fill the gearcase. The vent must be open to do either.
You need to get yourself an Owners Manual and a Service Manual and read both carefully before doing anything. That will give you the terminology and theory of the engine. Then you will be able to ask us any new questions.
Good luck.
