Re: 1960 Evinrude 40 HP, mercury switch
Envirude_boater I have the same engine like yours and same year.
I was wondering about those mercury swiches to, I got a hang pretty much how they work, F_R gave you the best description.
There are 2 switches one has 2 wires on it and the other one only one wire and I dont understand how it works with only one given that the other contact ( metal body) is not attached to the ground or anything else.
I have problems stoping the motor from the ignition switch ...do you have any problem?
Also on my vacuum saftey switch I have two black wires connected to the main lead but the manual shows only one wire.
Can you please tell me how many wire you have attached to the vacuum safety switch? or can you send me a picture is pretty rare to find somebody with the same year engine and model, I can help you with some other questions if you need.
I just completed the coils, points and cindenser replacement if you need help let me know.
''It looks as though switch one has been bypassed by a manual ground toggle switch connecting the cut-out switch to ground."
The reason they did that is because the previous owner had the same problem like me he couldn t stop the motor from the ignition switch, as the last resort I will do the same but I suspect that is something wrong with the wireing at the mercury switches or atthe vacuum safety switch.
