Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1960 Evinrude 40 HP, wiring diagram needed
  • 1960 Evinrude 40 HP, wiring diagram needed
    I have a Lark II (Model 35520) with the wiring changed a bit by a former owner. The white or tan solenoid wire goes to the throttle control. I can get the starter to crank but when I jiggle the throttle handle between "start" and "idle" I feel current in the metal engine cover and it seems to cut out the starter.
    There are three wires from the cut-out switch. One on the center post goes under the flywheel, the other goes to a toggle switch near the ignition key. The other wire under the flywheel goes to the toggle switch as well. The other wire on the corner post of the cut-out switch goes to the junction box but is not connected to anything. I seem to remember the seller telling me he had to install the toggle switch to kill the engine.
    Last edited by JB; August 14th, 2007, 08:24 PM. Reason: soliciting copyright violation
    1987 Doral Classic 200 Bowrider, 4.3 Mercruiser/Alpha One, 1970 Evinrude 9.5hp Sportwin, 1965 Johnson 5hp, 1964 Evinrude Speedifour, 1963 Evinrude Starflite and 1960 Evinrude Lark and when all else fails, Upper Canada Paddle Company paddles
    Re: 1960 Evinrude 40 HP, wiring diagram needed
    Ask for a diagram over at the Antique Outboard Motor Club's Ask-A-Member forum. Somebody over there will post it for you. aomci.org
    • #3
      Thanks FR, I'll give it a try.
