Hi,
Does the above motor have a water pump?
It looks to me as the prop wash is forced into the water cooling area. Its hard to run in a barrel and keep it cooled. Also removing prop caused it to heat up even more. Before I pull the lower unit I wanted to make sure there was a pump inside. My gut says no pump .....
Bill
Bill
