Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Symptoms of bad "Power Pack" ?
  • Symptoms of bad "Power Pack" ?
    What would be the symptoms of a Power Pack needing to be replaced?
    Re: Symptoms of bad &quot;Power Pack&quot; ?
    usually engine will run rough, what motor ? Symptoms? YOu'll wanna diagnose this one right bc power packs are generally not cheap.
    Chris
    Johnson - Evinrude Top Secret Files:
    Proudly Dedicating My Time To Antique And Vintage Style Outboards!
    • #3
      1985 Evinrude 115 Motor.
      We took it out to a lake near by and it ran fine for about 20 minutes, then it suddenly died. We tried to start it again and it tried to fire a couple of times but died. After getting a lift back to the dock it would start but only run for a few minutes. By the time we got back home it would run fine again.
      It was suggested by a boat dealer that I called on the phone that it might be the Power Pack, however, you never know how much knowlege people have, I thought I'd try and get some more info.
      • #4
        Is there a way to test this yourself?
        • #5
          I'm replacing my power pack tomorrow. We'll see if it was my problem. I had about 50 posts on here troubleshoot my ignition. If you search for 77Lark you might get an idea.
          I'll post my findings tomorrow.
          Adam
          • #6
            Bad powerpack -that is exactly what I would expect if the motor died like that because it would knock out two cylinders and shut you down under load.
            Then you get home and start it up with no load on the engine and wonder.
            I think you should ask the guy to explain what caused it to happen, and if the explanation is plausible, you better hire him.
            BTW, You may want to have someone check your rectifier to make sure that it is still charging. If you want to check it yourself, put a voltmeter on the battery with the engine off and take a reading. Then take a reading at the battery with the engine running and make sure that it is higher.
            • #7
              We're hoping to be able to fix whatever it is ourselves, as everywhere around here is booked full, and it wouldn't cost so much then. Is that a possibility or does a professional need to do it.
              • #8
                Its harder to diagnose than to fix, but it sure does sound like your problem. If you search 77larks thread like he said, i had a PP test in there you may want to try, follow his thread.
                Chris
                • #9
                  Knock out two cyl.? Mine has no spark on all four. Is that normal?
                  • #10
                    testing for electrical, several pages here. C & P without the "
                    "http://www.******************/page28.asp"
                    FLORIDA GATORS
                    TEBOW Country
                    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
                    That is what these forums are for. Post your questions, in the appropriate Forum.
                    • #11
                      To 77Lark: The 80's 115HP motor has two powerpacks, one for each bank of cylinders.
                      • #12
                        So is everyone in agreence that this is my problem, or are there other theories?
                        • #13
                          It could have overheated and locked up.
                          The flywheel could be loose.
                          The fuel pump could be bad.
                          You could have water in your tank.
                          Your ignition coils could be bad.
                          • #14
                            Are you saying that bad gas could have caused it?
                            • #15
                              Gasoline floats on water. The fuel pickup line is at the bottom of the tank.
