ErinMarie1501
- Aug 7, 2007
- 20
What exactally is the "Power Pack", and what does it do?
Could I suggest, it's not so much the absence of the 300 volts in the primary winding as it is the sudden decrease in current caused by the SCR shutting off. The magnetic field generated by the current through the primary ... Oh never mind. Supper's ready.could I suggest that it's not the 300 volts in the primary winding, so much as the absence of it, that induces the high voltage?
The capaciator is charged to roughly 300 volts DC. Which simply means it has stored a bunch of electrons. When the SCR is fired it causes the capacitor to discharge through the coil's primary winding as a short pulse of current. The rest of the time, the coil's primary effectively has no current. It takes a peak reading AC meter to read the voltage. Otherwise, the voltage level would be averaged for a reading which would be very low. The term AC can be somewhat misleading in that AC is short for alternating current. Which implies current flowing back and forth in opposing directions. The current from the power pack only flows in one direction. But, if you reference the measurement of that current as being the average level, the current does go in opposing directions past that point - thus AC.
