Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1975 johnson 40hp outboard motor flooded?
  • 1975 johnson 40hp outboard motor flooded?
    took the boat out today got it to the water ran good at low idle. then i got out of the no wake zone. i gave it all she had. we were going at a good pace. got about half way across the lake then the engine spit and sputtered and stalled out. tried to start it back up again and it turned over but didnt start. so i took the cover off the motor and had my friend try to start it. it didnt start so i told him to stop trying. when he turned the key to the off position gas shot out of the carb. what would that mean im thinking flooded. how would i fix it. i took the carb off when i brought it home. and looked at the float and everything seemed fine. i rebuilt the carb about 2 months ago when i bought the boat so it has all new parts.
    my boat
    http://forums.iboats.com/showthread.php?t=243841
    http://forums.iboats.com/showthread.php?t=308089
    Re: 1975 johnson 40hp outboard motor flooded?
    Were you choking the snot out of it while trying to start? That could explain the fuel.
    Jack of all Trades, Master of None
    • #3
      no i do that when i go to first start it it starts up easy when it is warmed up.
      and onther thing i noticed was after i took the carb apart and put it back together i pumped the bulb up and gas poured out of the carb.
      my boat
      • #4
        Needle and set or float trouble.
        • #5
          i have another ?. is it posible to pump the bulb to much. where gas will come out if everthing is in working order
          my boat
          • #6
            No, you can't.
            Back to Top
