HI- This is my first outboard rebuild. I just bought a boat with a 1978 Stinger 75hp (75ELR78C). The flywheel would only turn about ?45?. Once I split the case open I found the lowest connecting rod cap only finger tight. What do you guys think about applying loctite to the rod bolts and torque to spec?
Thanks
Thanks
