VaBeach1234
- Jul 11, 2002
- 22
Okay guys. I did some searching on this site about adding a tell tale or a pee hole, what ever you want to call it, to a 1971 Johnson 50 hp. I found a lot of info on other motors but not my motor. Here are some pictures with an arrow pointing to where I think I can drill and tap a hole for the telltale. Do you think this is the best place or should I drill in to the exhaust cover and if so, where on the exhaust cover should I drill?
Thanks.
Ken
Thanks.
Ken
