Johnson seahorse age/rebuild info?
gwhaling
It's old just not sure how old. Model RDSL-22C serial #2135318. Any idea what year. Magneto ignition and wire screen for intake filter. It has bad bearings in lower unit, need a good article on pulling lower unit on apart. If no info is available on line who has best manual on this motor? I will search a original vintage Johnson manual on ebay if their good.
Thanks, Glen
gwhaling
Re: Johnson seahorse age/rebuild info?
Thanks for the link on age.Looks like a 1960 model. I have searched under seahorse lower units and did not find any info on getting lower unit gears/shafts apart, any good articles available? If not best manual recomendation, or which manual to stay away from.
HighTrim
Go for the original manual, search ebay. Will run you about 30 bucks, but well worth it.
