I have a reccurring problem of the inline fuse near the solenoid blowing the little size 4 fuse. If I put in a size 7 (same 32v) it does not blow. Engine was running like a top, stopped to fish...then this all started. Solenoid has been replaced. Replaced switch, (with care taken to wrap scews adn terminals inn electric tape before installing in remote box.
WHen it will crank it may run for a few minutes then die. I have checked fuel lines, filter looks good, will pump fuel when squeezing bulb with hose disconnected at T for carbs. When fuel line connected all the way the bulb seems hard to prime. Any thougths?
BTW If you fix this I will be on standby for any computer issues you have ( long time IT manager)
