Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
evinrude year/mix ratio???
  • evinrude year/mix ratio???
    i have 2 outboards and do not have a year or mix ratio for either can someone please help. 1 evinrude fastwin serial# 18302L-E02482 and 1 evinrude fisherman serial#6602E-E04674.
    Re: evinrude year/mix ratio???
    18302 is the model number, indicating the engine is a 1963 18hp Evinrude. Mixture is 50/1 as powerhead incorporates "all" needle, roller, and/or ball bearings.
    6602E is the model number which indicates that the engine is a 1966 6hp Evinrude. Mixture used is normally 24/1 as most powerhead bearings are the babbit/bushing type. However, there are thousands of these engines using the 50/1 mixture with no ill effects. I myself have used that 50/1 mixture on the various year 6hp engines and have encountered no problems.
    Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
    • #3
      thank you, very big help!
