Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
1977 Ranger 1750 w/Johnson 115 only hits 39MPH
  • 1977 Ranger 1750 w/Johnson 115 only hits 39MPH
    I bought a 1977 Ranger 1750 Fish/Play. It's the Sport or tri-hull design. Plains out right away, the engine is running at 4,800 trimed down (5,000 is max). Prop is a SeaBold 13 X 19 Stainless. The tilt is not working properly, but i took off while trimed up (slowly to not overrev) and i was able to get 40MPH and spining at 5,200. The MPH was figured on GPS so it's right. Calm water, average to cool air temp, 2 people on the boat, livewells empty, and otherwise lightly loaded (the boat, not me). Any ideas what this hull should run?
    "2 strokes", get it done in half the time!
    Re: 1977 Ranger 1750 w/Johnson 115 only hits 39MPH
    do a compression test sounds like you have low or dead hole
    • #3
      Already been done. Compression is about 125 in all holes. It varies maybe a pound or 2 at the most. About 1,100 above sea level.
      • #4
        The engine's horsepower is rated at 5000. The normal operating range is 4500-5500. Suggest you try a 17 pitch. You need to be in the 5500 range. It's only 92.6 cubic inches-the small displacement engine.
        • #5
          being a 77 check for extra weight, such as water saturated form.
          FLORIDA GATORS
          TEBOW Country
          Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
          That is what these forums are for. Post your questions, in the appropriate Forum.
          • #6
            You need to get the trim up and running and make sure the motor is not too low in the water as well.
            sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
