Searched a while on this, couldn't get a straight answer. I have an 87 110 bubbleback V4 that I replaced the thermostats and water pump in. Cranked it up today on ear muffs and only got cold water from the tell tale. Heads were not overly hot to the touch, I could keep my hand on them a while. No water coming from the exhaust bypasses but I figure this is because there was no backpressure from running on the earmuffs. The bubbleback stayed cold as the water coming from the tell tale (garden hose temp.) Did I screw up the t-stats? I used a Sierra kit with all new grommets, springs, t-stats, ect. All my other OMC's (2cyl's) had lukewarm water coming from the tell tale, I think I may have a problem. Any thoughts? Thanks a bunch for your help.
