OldAmerican
- Jun 24, 2007
- 19
I inherited a '51-'52 Johnson 10 hp engine that I was having trouble starting so took to a shop and had it gone over. Guy worked it over and said it was good to go. But I still have a hard time getting it to start and stay running once it does start (dies when you put it in gear). I figure it has something to do with setting the controls on the front of the engine. Does anyone know how to properly set them for starting and running? And what exactly is the correct starting procedure for this engine. No owners manual and the instructions on the case are worn off.
