I've installed a new Optima battery in my boat and it's been tested to verify it is at full charge. The connections are good but I get no activity what so ever when I use the power trim buttons either on the motor, on the throttle or in the front of the boat. When I turn the key, there is no sound whatsoever which makes it seem like there is a short somewhere. I called my local Evinrude Dealer and they think that I just popped a fuse. The problem is I'm not sure where the fuses are located. I'm assuming that they are in-line fuses somewhere under the cowling but can someone help me figure out where to look? It is a 1999 model year FICHT I believe.
Problem Solved
Problem Solved
