Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Charge Coil & Sensor Coil Output ?
  • Charge Coil & Sensor Coil Output ?
    I have a 1996 88hp Evinrude. I am using a Fluke multimeter with a CDI peak reading adapter. The Clymer repair manual says I should get 150 volts or more when the charge coil is checked. I am getting 346 volts. Is this okay? The output of the sensor coil is supposed to be .5 volts on each pin or more as the manual states. I am getting approximately 2 volts on each pin. Is this okay? How much can "or more" be? All help will be appreciated.
    Re: Charge Coil & Sensor Coil Output ?
    Your reading's are correct on both components
