Re: 1992 Johnson 150HP Silver Star Series
When the engine is initially started and in nuetral, it will make a "spitting" sound every few seconds followed by a stall. Easy starting again but will repeat the spitting and stall again. if I push the ignition primer in while running the spitting stops. Also shifting into forward or reverse (under load) seems to stop the spitting.I have twin outboards and the other engine does not act up this way.The local marina mechanic says "running lean".
