Where do I start.Bought boat, when I first took boat out the idle was rough and very hard starting,after warmed up boat would start great and would always run great past idle.Took boat out about 7-8 times and it blew up.Rod looked like a twizzler after all was said and done. Sent power head out for rebuild, new crank /sleeve/rods and pistons etc..the whole nine yards. Place where I purchased boat installed powerhead for me and did a Decent job.Problem is now boat idles worse or as bad than before spits and pops and at idle it will act like it wants to stall out when it does the motor will actually start running backwards until it spits again then will start running normal direction.
Any Ideas
I'm thinking Carb rebuild and sync and maybe some timing issues
Any thoughts
Boat is now at a different dealer waiting in line to be looked at
Any Ideas
Any thoughts
