Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Oil Fuel mixture on 1984 Johnson 90 HP
  • Oil Fuel mixture on 1984 Johnson 90 HP
    I have a 1984 Johnson, 90HP that I have just purchased. I need to know what the Oil mixture is. It does have an oil port for a VRO Tank (I think this is what the tank is called) but I have read that the reliability isn't very good on the tanks. This is the first motor that I have owned that has an option for a oil reserve tank. Please tell me if the information that I have read is true or not and also what the fuel to oil ratio is. Thanks in advance.
    Tony
    Re: Oil Fuel mixture on 1984 Johnson 90 HP
    ratio is 50-1 tcw 3 oil. the early mixers were some what unreliable, read the post in the faq section about them, 2 good post. http://forums.iboats.com/forumdispla...c&daysprune=-1
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      The VRO in 84 wasnt the most reliable. They upgraded it in 85 or 86. Mine crapped out numerous years ago and I removed it and now pre-mix. 50:1 is the ratio. 1 pint of oil to 6 gal of gas I believe.
      1984 Cimmarron bassboat 16', with a E90TLCRD, 13.5 x 18 Raker SS prop, Minn Kota 55AT trolling motor.
