the driveshaft was frozen in the crankshaft soaked for two weeks , tried wedges ,heat,ect hung moror upside down; my question was can i remove the remainder of the driveshaft from the lower end without removing prop shaft.cutting was last resort . still cant remove remaining piece from crankshaft. have to weld nut to shaft and use slide hammer
