Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Warning Horn Test
  • Warning Horn Test
    1989 1.6 SeaDrive
    I would like to test just the warning horn itself to make sure it is working.Is it just a matter of hooking it up directly to the battery?
    Re: Warning Horn Test
    There is a sleeve on the tan wire from the temperature switch a few inches from the cylinder head. If you slide it down, and ground the control end of the wire to the engine block, the horn should sound if the ignition key is in the run/on position.
    • #3
      The horn should beep when you turn the key on.
      • #4
        I have a 1988 control that does not have that start up beep, instead, it has a slot located above the ignition and under the warm up lever into which you can insert a second key. You have to raise the warm up lever to access it.
        With the ignition on and the second key inserted in the slot, the horn will sound.
