Re: Evinrude 18 hp Convert to 25hp
A carburetor works by the fact that air is flowing through it, and the speed at which the air is flowing. An engine running at 4500 rpm pulls a certain amount of air through the carburetor. An engine of equal displacement running at 5500 rpm pulls roughly 22% more air through the carburetor. So the venturi (hole through the carb) has to be larger for the increased volume of air to flow at the same speed. Put the larger venturi on a slower or lower displacement engine reduces the speed that the air flows, disrupting the efficiency of the carburetor. That's why just slapping on a bigger carb doesn't work. If it did, you could just put on a 100hp carb and fly!
OK, so you say the bigger carb will let it turn 5500 rpm. Not so. The horsepower isn't there to make it go 5500rpm because you didn't change the other items.
Now, it is true that in some cases, the different horsepower ratings are achieved by just taking a certain engine and putting a smaller carb or restrictor on it. But that is not the case in the motor we are talking about here.
BTW, I spent considerable time checking the differences on this motor and they are carb, pistons, and cylinder head. The block and exhaust are the same.
