Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
universal tachometer
  • universal tachometer
    hi,
    I find universal tachometer for outboard engines and i want connect on my johnson 130,2000year,i have 3 wire,ground,+12v,and wire G-generator,where connect this wire on my engine
    thanks
    Re: universal tachometer
    There should be I for ignition + (purple), G for ground - (black), S for sender (gray).
    Hey, Have you seen? They make Really Cool life preservers nowadays.
    So "Looking Dorky" is no longer an excuse for not wearing one.
    • #3
      hi
      yes,but how connect sender on engine?where?
      thanks
      • #4
        There is no sender to attach to the engine. It operates of pulses from the alternator. Just find the gray wire coming from the engine (Usually at the terminal board in the engine compartment) and hook it to the send terminal on the Tachometer....
        Rick
        "Boating is Life...All the rest is just Details"
        2007 Bentley 200 Cruise
        2007 Merc. 90 4 stroke
        • #5
          If you have side mount throttle/shift controls, there is a three pin connector just under the ignition key. You need the tachometer harness which is available from a dealer, here on iboats, or you can make your own if you have some electrical skills.
