Re: 25hp Johnson - the good and the bad?
I have both an '82 15 hp evinrude, and also a '70 25 hp 'rude... both see action on the same 16' aluminum fishing boat. (tiller type with 4 cross seats, no carpeting or live well).
Mostly ditto on what's been said above.
With an empty boat or a very light load, there is surprisingly little difference in top end speed. But, if you get a "normal" load of a couple people, some gear and a smelly yellow lab, the top end speed with the 15 hp drops quite a bit. It makes less difference when I have the 25 on the back.
The 25 (at least mine anyway) is not even in the same league when it comes to idling/trolling. It's a sputtering / stalling annoyance compared to the 15. It (the 15) idles down smooth as silk and will tick over like a sewing machine for hours on end.
So, when I'm going fishing (trolling) I either use the 15, or more often, stick my 6 hp beside the 25 and just use the bigger motor to run from spot to spot. I have even had both the 15 and 25 hp at the same time (15 for trolling).
FYI, I find my 25 hp to be enough of a PITA to move around, that I usually leave it locked on the boat for weeks at a time. But, I the 15 is handy enough to take off and lock in the boathouse. It feels like the weight difference is bigger than it actually is IMHO. (the 25 feels more piggish than I'd expect)
I also find the 25 is louder and lots more thirsty than the 15....
I don't think that the 25's are bad motors, but I think the 15's are particularly good & smooth. One of OMC's best I think.... Depending on what you want the 25 to do, it might be the hot ticket (pushing moderate to heavy loads) or it might be disappointing (light loads and lots of trolling).
that's my $.02.
